jodeb720
Aug 08, 2021Explorer
Coleman Mach III 13.5 btu replacement
after 11 years, my ac unit gave up the ghost.
I have run my ac on my honda 2000 - but when it's really hot (above 90) it's exceeding my Honda's running capacity.
The Honda's rated output is 13.5 amps at sea level (with a 16.6 amp 20 minute 'burst').
I know, I could buy a higher rated generator, but I don't need the AC that often and if I could get away with a higher priced AC unit that would draw less amperage, maybe it might be enough.
how much less amperage will a power saver reduce the amperage consumption on a replacement Coleman Mach III PS?
thanks in advance,
Josh
thanks in advance,
Josh
