dougrainer
Apr 13, 2015Nomad
If you have the LCD screen on the Tstat and ON Electric heat, the LP furnace will come ON if the set temp is more than 5 degrees from the interior temp. If the interior temp of the RV is 60 degrees and you set the heat temp (Heat Strip) to 66 or higher, the Furnace WILL come on until the temp spread is within that 5 degrees. 60 in the RV you set the temp at 70, when the interior temp reaches 66 degrees the Furnace drops out and the Heat Strip continues to attempt to heat the rest of the way. Probably will NOT as a Heat Strip is not designed to heat the RV, just take the chill off. Heat Strips follow the same parameters of a Heat Pump on operation. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
