RustyScupper
Apr 13, 2015Explorer
LadyRVer wrote:
On my unit, if I set the thermostat for more than a 3 degree difference (in the elec heat mode) the furnance will kick on with the elec heat until it catches up, then furnaces stops and elec heat takes back over.
If major difference in coach, I just start with propane furnace, wait until it reaches about 45-48 outside, then switch to elec heat to maintain.
Hmmmm - This is the first time it has happened. Maybe it is suppose to work that way. Might have to think this one thru before I buy a new thermostat. 90% of the time I am boondocking and no AC so this is the first time it has happened and may be an "undocumented" feature.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
