dougrainer
Apr 13, 2015Nomad
LadyRVer wrote:
On my unit, if I set the thermostat for more than a 3 degree difference (in the elec heat mode) the furnance will kick on with the elec heat until it catches up, then furnaces stops and elec heat takes back over.
If major difference in coach, I just start with propane furnace, wait until it reaches about 45-48 outside, then switch to elec heat to maintain.
Do you have the Dometic Roof units with the Dometic Tstat? Most Monaco's used Dometic. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
