dougrainer
Mar 03, 2018Nomad
1. Your warranty will not be affected
2. NOBODY will notice the Supco add on kit if you have a warranty problem
3. OEM's can have RVP install the Hard Start Kit from RVP as original equipment if the OEM desires too. Some OEM's will do that on Towables, because they expect some of their customers will be using NON RV Gensets to run the roof AC. Here is how to tell if the RVP has a OEM hard start kit. You do not have the RVP Hard Start kit. Doug
2ND NUMBER AFTER THE LETTER IN MODEL NUMBER TELLS THE TALE
IF 5 O6 THEN NO HARD START KIT
IF 7 -8- OR 9 HAS HARD START KIT
