j-d
Sep 24, 2015Explorer II
When you go up there, you'll take the plastic shroud off then the cover plate noted above to look at the capacitors. If you possibly can, take pictures of the capacitors and the wiring diagram that I think you'll find just forward of the capacitors. If you can't do that, please provide the model number of the A/C, should be on or near that wiring diagram.
To determine if compressor's trying to start, one or more of the following is useful:
A volt meter
An amp meter
A helper
Got any of those? Which one(s)?
A volt meter
An amp meter
A helper
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
