MR_MAC's avatar
MR_MAC
Colman AC board - where to get one
This was posted on "5th wheels" but no results, but my friends oolman AC unit some times will start and run and some times just the fan runs, taping on the (120V) relay on ele board, the compressor starts and runs. ? is where can we get a new board, or mabey just the relay and solder it on. Its a Colman 7300 on a 1998 Avion. Its a Colman Mod# 7335B896. Thanks for any advice. Rob.
  • dinosaur boards are made well if you need to replace one.
  • Check eBay and Amazon... I've found parts on both and was amazed they had what I was looking for. Best wishes.
  • I have never bought from them but people often recommend Dinosaur Electronics. Look closely at the board with a magnifying glass. You will sometimes find that a relay or other connection has broken loose at a solder joint. They can be hard to spot but could very well give an intermittent condition that you mention and easy to fix.
    Coleman
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
