westend
Jun 04, 2013Explorer
I have a bank of three 12v AGM's and a bank of two 6V GC2's. The two banks are in separate but close locations (less than 8'). I have a small dorm fridge that operates at 80w. Solar is my primary battery charger.
I decided that I wanted the functionality to switch between banks for charging and supply. I accomplished that by using a distribution panel with three battery disconnect switches.
Schematic:
In real world use, since I can set the charge parameters of the solar controller, both banks can be in parallel for charging and supply. The OP's FLA 12v's may not be as forgiving as the bank of three AGM's or four 6v's may require more of the charge than the two 12v's. This could be done, manually, with disconnect switches or electronically, with a solid state battery isolator. The most elegant solution may be to use six 6v's and sell the two 12v's.
Schematic:
Having RV issues? Connect with others who have been in your shoes.24,368 PostsLatest Activity: Mar 11, 2026
