McKenziek
Jun 04, 2013Explorer
smkettner wrote:
How old are the 12s? Would you have headroom for L16?
Under heavy load and charging (100+ amps) you could run into some balance issues that may wear on some batteries more than others. For small stuff (furnace and lights) it is a minor issue IMO.
Got solar on the list? If not I would disconnect the parallel connections if stored without a float charge.
They are brand new and under the stairs in a compartment too small for the 6'ers. Plans are for solar and a better charger with the goal of having enough storage to run the fridge all night without going below 12.06 volts. Wanna take a stab at how many amp hours a full size residential fridge will need to survive all night on?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 11, 2026
