mena661
Jun 05, 2013Explorer
McKenziek wrote:Thanks. :) The compartment is steel but I did use two 1/4" pieces of plywood on the bottom of the compartment. Eventually I will probably get someone to weld a steel or aluminum plate on the bottom of the compartment cause I want to get longer slides (I want the batteries to slide all the way out).
Mena, just checked out your sliding battery tray setup. Nice. Did you have to reinforce the compartment below to handle the weight? All my compartments are cheap plastic bins suspended by sheet metal screws so I have some fabrication to do.
McKenziek wrote:Hmmmm. Unless the info in the link is wrong. I would call the manufacturer and see what they say. Should be entertaining.
False Advertising?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
