Almot
Jan 20, 2014Explorer III
westend wrote:
It has a very small freezer tray and that could probably be removed, if unwanted.
Freezer tray is normally an evaporator in the shape of "sleeve" with cooling tubes imbedded in there, so you can't remove it. Un-folding it into a flat evaporator or removing that small freezer lid could work though.
OP - make sure it is indeed a compressor. Some of those small fridges are thermoelectric, not compressor. Walmart used to have some $60 1.7 cu.ft.
Having RV issues? Connect with others who have been in your shoes.24,388 PostsLatest Activity: May 21, 2026
