BurbMan's avatar
BurbMan
Explorer III
Apr 04, 2022
Compartment latches and locks
I've got some very large storage doors on the basement of the 5er with the standard-issue CH751 locks. The locks are finicky, and the quart-turn stops are all broken on the latches so they spin around and around, leaving you to guess when the tabs are actually engaged to the frame and holding the door closed.
I upgraded to the round 7-pin tumbler locks on the previous TT and they were a little better but don't think I will go that way again. These are typical towable 3/4" thick storage doors, not the heavier Class A doors that use slam latches. Several of the doors are so big that they have 3 latches, 2 thumb turns with a locking latch in the middle.
Any suggestions for "upgraded" latches?
  • I hope we are talking about the same latches. I find I have to disassemble mine every couple of years, clean and regrease the ball bearing for smooth operation. The stops are solid leading me to believe your entire lock may be rotating. I would check to see that the outer bezel isn't moving.
    My trailer came with combination locks on some of the hatch doors and I would advise against them. I have to get the readers out to see the numbers and my eyes are pretty good. Plus, they have a large serrated handle perfect for Channellocks.
  • Hope there are some good answers to this. Having same issues with my older RVs. Problem now is they have tried to make different keys in sets so everyone with an RV can't open your RV compartments. But then you have some locks with one key number and some with another so you need more keys on your key ring.
    Trouble is the sets of locks you get in a bag have keys made of some cheap metal that twists with the slightest turning strain, and the ends break off in the locks, and the keys get stuck in the locks so you can't pull the key out. It is all very frustrating.
    The compartment doors are so thin but not all the same so you have to get the right length to fit. As noted in the OP, the catch to keep it in place is not very good. The screw holding the latch tab won't stay tight either.
    Needs a dedicated spray can of penetrating oil just to keep all the locks working each trip. Phooey! So I'm with the OP hoping for the correct answer.
    Here are some, no idea which are any good.
    https://www.amazon.com/rv-compartment-locks/s?k=rv+compartment+locks
