Mello Mike wrote:
I recently made the switch from the CH751 to tubular cam locks. The full details can be found here:
Tubular Cam Lock Install
Good luck!
my install wasn't quite as easy as the article indicated. a couple of the holes had to be enlarged very slightly to get the new locks in and the replacement locks were slightly short and I had to grind away some of the plastic on the inside of the doors to be able to properly tighten down the retainer nut.
Before when I redid my Flair many years ago I ordered a matched set from CW. this time I just grabbed enough off the RV dealer's shelf that had the same key number.
bumpy
