Bob_Landry
Mar 08, 2014Explorer
BoonHauler wrote:
I called Norcold today and was told Sawafugi. They said nothing about Danfoss.
Then you need to find a different source at Norcold. I found several models on their website that use the Danfoss. Look at the specs for the fridge. If it says it uses 110V-12V-24V it is a Danfoss. The Danfoss power supply will internally switch to accept either 12 or 24V and given AC or DC will default to 110VAC. the power supply on the Sawafugi units will only accept 110VAC or 12VDC.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
