BoonHauler
Mar 11, 2014Explorer
BoonHauler wrote:Bob Landry wrote:BoonHauler wrote:
I called Norcold today and was told Sawafugi. They said nothing about Danfoss.
Then you need to find a different source at Norcold. I found several models on their website that use the Danfoss. Look at the specs for the fridge. If it says it uses 110V-12V-24V it is a Danfoss. The Danfoss power supply will internally switch to accept either 12 or 24V and given AC or DC will default to 110VAC. the power supply on the Sawafugi units will only accept 110VAC or 12VDC.
Bob, I'll give them a ring Monday morning to verify your information. This is why I'd like to get more feed back from everyone, thanks.
Bob:
I called Norcold today and pressed the issue and you're right, all but one model(#DE 788 / EV0788) are equipped with Danfoss compressors.
I also spent some time searching the RV.net database for related information and can see that you look like the expert regarding these units.
Thanks for all your input, it's greatly appreciated.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
