wa8yxm
Mar 14, 2014Explorer III
Bob Landry wrote:
What have you "seen" that validates that claim? You really shouldn't shoot from the hip with blanket statements like that unless you have the background to validate it.
It is not so much what I have seen as what I have not (up to that point) Seen.. (your comments which I clipped out).
Ok, I will accept the Danfoss is better made, and of higher quality... By the way, Though I said I had not seen (up to that point clearly) anything to suggest that.. (now I have but I will request a bit more). it makes sense that one would be better made.. A bit like the difference between the original Atwood control board in my Furnace v/s the Dinosaur board that's in there now.. Dino way better built (on that I am qualified to comment as I have the training, the wall paper and both boards side by side to look at at the time).
Now... on to what I need to absolutly be sure.
you say you've replaced only a couple Danfoss but many of the other make.. I am assuming you have actually seen a similar number of both.
Cause if you have seen say 1,000 of one and 20 of the other.. Well. (Then it would be kind of like a Ford Dealership mechinic saying he fixes more Fords than Chevys).
I am, however, assuming if that were the case you would have said so. But.. Well.. (I'm saying I trust you but I also worked as a police dispatchers and they taught us to ask for proof).
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
