jlscjs's avatar
jlscjs
concertone removal
I cannot get the gray colored trim removed from my unit, I read to remove from bottom first and have tried to insert a screw driver into the tabs but it will not come off, any ideas?
  • craig7h wrote:
    I have a older model, feel underneath. There should be two slits one one each side,use those to pry cover ring off. Once off you will be able to seem mounting screws.
    Ours is in a 2010 year model & as Craig7h says use a screw driver to push the tab in the slits. Unless yours is like our & mounted close to a wall, therefore I made a L bent nail to push in the tabs.
  • I have a older model, feel underneath. There should be two slits one one each side,use those to pry cover ring off. Once off you will be able to seem mounting screws.
  • Which model? Mine is simply held in place with 6 screws theough the front
