Lost_Traveller
Apr 25, 2016Explorer
Thanks for all the advice. We went with the TST 507 flowthru's. Just got them in the other day. Now, I have a couple of other questions. Actually it's three.
What is the variance you use between your low and high PSI? My tires are "E" rating at 80psi. Would I use a 10% variance?
I have seen some talk(I think mostly about the tire minder system) about having to have brass valve stems because of the weight of the sensors. What about the 507's? Hopefully, I don't need to change my valve stems.
Last question...the high temp is preset at 158 degrees. I think that the TST is normally for semi's. Would the temp rating be the same for RV tires?
Ok, that's all. Any help would again be appreciated.
Connie and Bruce
the Lost Travellers ( or it it one "L"?)
Connie and Bruce
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
