JimK-NY wrote:
.... That will be over 100 AH of charging over the course of the day. Where is it going?........
Which might go with my, ".... For voltage to drop so low in a brief time, there must be quite a load on the batteries, or they are in hard shape, or something is going on."
You could have a mystery load on the batts. Tank heater, breakaway pulled out, inverter with something 120v running from it, etc--the usual suspects?
What is your "morning voltage" with nothing much on and before solar starts in? If the two batts (still 300AH?) are at 50% SOC then, you can put 150 in to fill them--so 100AH is not a crazy number unless you are starting the day at 80% SOC
(I thought that 13.6 was being on Float, not passing through going up in Bulk, sorry.)
