SoundGuy wrote:
bgum wrote:
If you need say 25 amps and you parallel two base 2200 units you are out of luck. Their circuit is only good to 20 amps. Where companion circuit is good for 30 amps when parallel. It costs you more but gives you more abilities.
Not really - just DIY your own parallel box with a TT-30 receptacle. Here's one example. JMO, but my own choice would be 2 identical standard EU2200i gensets rather than 1 standard & 1 Companion.
OP Here,
Due to disabilities and health issues I didn't Want to get into making my own cable, I went out to eBay and found this:
Parallel cable with RV AdapterWould this work connected to two Honda 2200I generators?
Thanks!
Dave
