Dutch_12078
Nov 11, 2016Explorer III
You need a 4-port "Extend-A-Stay" type of adapter. The adapter screws into the fixed ASME tank service valve on one side and the regulator is connected to the other side. It has high side connections for both a BBQ or other self regulated device and an external DOT LP cylinder. The adapter you have does not allow a high enough flow rate at the external hose port to support multiple devices like a furnace and water heater.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
