D_E_Bishop
Nov 11, 2016Explorer
To answer your question, your fine as is. You will need a hose from your new cylinder to the "T" attached to your tank. You can go to a lot of places to buy the hose you need to attach your new cylinder to the fitting you have now. Pretty much it is a hose with a Type 1 tank fitting and a fitting that is the same as the fitting on a 1lb bottle. If you already have a hose with a POL fitting you can use that one.
Simple no big deal.
By the way, Marshal Brass is now Marshall Excelsior Company and Extend a Stay is Sturgisafe. Camco also carries all the fittings but all you need is the hose.
Simple no big deal.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
