n7bsn
Oct 22, 2015Explorer
mkirsch wrote:
BTW, there are no "signal cables." The bullet connector cables are POWER CABLES. The bullet cables are hot and neutral, so make sure you match them between the two generators.
100% correct.
Yes, it should work (I've actually dug through the schematics, specs, etc of the Honda). The way their circuit is designed, it senses for voltage on the output, if there is AC voltage there, the circuit tries to sync up the output of the inverter to this voltage, if it can't it trips the safety and stops trying.
All that being said, I've never tried tying the Honda to a "hot main" and starting it.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
