BFL13
Aug 07, 2015Explorer II
pianotuna wrote:
Just do it. It is not as if you are dealing with 90 amps.
If he has the 80amp PD going as well as say 20 amps of solar, he would equal his 100 amp fuse on that path. If he passed the solar along the inverter wires it would only add up to the solar amps on that 80 amp fuse there.
I am not clear on what happens if the amps are opposing direction on the same wire. What would the solar controller think is going on if it is trying to pass 20 amps to the battery along a wire that had 10 amps coming the other way to the inverter?
You do have inverter/chargers using the same DC wire set for both functions, but I am unclear if that would ever be at the same time.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
