BFL13
Aug 07, 2015Explorer II
pianotuna wrote:
He will never see 20 amps of solar.
Amps will only go one way if the inverter is drawing more than the solar panels are producing.
I think he is using battery voltage sense wires.
Yes he is. Three 120s is 360w at three times 7.6a aimed (22.8a) but his are flat so will be less depending on location and time of year how much less.
I am just having mental problems :) seeing the voltages at each end of the wire what with the controller doing its PWM in Absorb, the load with voltage drop at how many amps, and the actual battery voltage so you get "net" flow from high to low. But this isn't about my brain's weaknesses, Fisherguy wants to know which way to wire his set-up.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
