BFL13
Dec 15, 2013Explorer II
Yes you can connect the output of your solar controller to the output of the converter, so they are in parallel on the battery.
EDIT per above-- Be sure the second set of terminals is connected to the first set or else just use one set of converter output terminals for both controller and converter
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 30, 2026
