RLS7201
Dec 16, 2013Explorer II
sdmotor wrote:
Is it possible to connect the output from my charge controller to converter instead of direct to the batteries? I have the PD 9100 series that has two sets of pos and neg terminals on it.
Yes, It will work just fine.
I installed 500 watts of solar and put the charge controller in the same compartment as my PD9180. I wired the charge controller into the second set of terminals, as you purposed. It's a no brainier, if the wiring will handle the PD9180, it will handle the solar. In my case voltage drop is not an issue. My charge controller has a separate voltage sense lead.
Richard
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 29, 2026
