DrewE
Mar 05, 2018Explorer III
On mine, the AC ground and neutral connected to a little bottle-cap like doohicky on the inside exactly opposite the DC ground wire connection. The AC hot connected to the circuit breaker on the generator. To get at them required removing a bunch of the secondary parts inside (the control/regulator boards, starter solenoid, mounting plate for the circuit breaker/fuse/start switch, etc.). It was pretty straightforward, everything using the same size Torx screw and having connectors to unplug where needed, but it did take awhile to undo everything.
I don't think disconnecting it from the junction box was practical on my installation; I think the wires run straight to the transfer switch, though I may be mistaken I haven't come upon an intermediate junction box, at any rate. Your installation may well be different, of course.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
