NomadusExplorerOct 12, 2017Continuity puzzlerThe lugs on my fuse board for the positive and negative battery connections have continuity between them with all fuses pulled and leads disconnected...what am I missing?
MrWizardModeratorOct 12, 2017probably the filter system or bleed resistor in the converterI assume you had some reason to be curious and its not blowing fuses or creating major problemssince none were mentioned
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related ContentDeath Wobble Continues ....The RV Demand ContinuesTire puzzlerPUZZLER: Slides & jacks are deadA genuine Propane Puzzler
