The lugs on my fuse board for the positive and negative battery connections have continuity between them with all fuses pulled and leads disconnected...what am I missing?
All the above plus there are filter capacitors on the output of the converter that will show some resistance until your ohm meter charges them. If the resistance keeps changing as you watch it, that's what it is.
