befu's avatar
befu
Continuous failure of TT wheel bearings - I am so ashamed...
Hello, have a problem that I need to ask for some input on. Bit wordy with a 4 year history to tell, but here we go. We have a 2012 Puma 31dbts trailer that we have camped in 4 summers now, love it! The second year camping with it, I believe I over heated the brakes pulling around Ohio Pyle State Park in Pennsylvania. Did not notice damage then, but that is the first time I noticed the hot smell after towing in hills. (Yes, down shift and control speed, thought I was, last grade was rather severe and no shoulder. Learning as I go... anyways, they got smelly hot.) Rest of trip went well, had a blast.
Later that summer, 2nd year, I had the left rear bearing fail on me and it was pointed out by a passing vehicle. Outer bearing was shot, nut had some damage from hub wear, spindle did not seem to take damage. So I put a new seal, both bearings and cups in it with a new nut and went home without issue.
The next summer, third camping, I fought bearing heat issues. Never lost a bearing, but the two right side bearings would get hot. The front left side was cool, back left side was slightly warmer, right rear was getting hot and front right was about 10 degrees warmer. You could put your fingers on the hubs, but not for more than 5 or 6 seconds. I pulled them apart, put new bearings in and reset everything. Still getting warm, so replaced bearings, cups and seals. Would be better, but still get hot on 2 hour tows.
So last summer, 4th season, we had a big family trip out to Yellowstone from Indiana. I said the heck with it and purchased and installed new bearings, cups, seals, nut, drum and brake assembly from etrailer for the front right side, since that was the hottest one. Seem to do better and later we headed out on that 3,000 mile tow trip, which I constantly fought and worried with hot bearings on the right side of the vehicle. Left side was fine and cool. Last summer was pretty cool, so hot temps were not bad. Here is the kicker.
Made it out west and back to Wisconsin and I was waved down by a driver next to me about a rear wheel. Pull over and sure enough, that back left wheel bearing was shot again! Needed a new drum, nut and bearings as it wallowed out the outside bearing hub race location. All this with no indication of trouble like the hot bearings on the right side. So fixed that and while it works, it is still running warm while towing. Sometimes OK, sometimes a bit warm. But I do not feel safe towing right now. Now I am looking at what to do getting ready for the upcoming season.
The main thing that bothers me is I have not replaced anything on the one cool hub, but have adjusted brakes and greased the bearings. I am mechanically inclined, work on equipment all the time, fighting with am I the cause of this? Bearings are not that hard, I do not know what I am doing wrong. Have a full shop with presses, lathes, mill..... all kinds of toys. Have run bearings a flat loose so you could just feel a bit of wobble or give. have tightened one flat and also ran them an extra flat tight. All the same. One wheel cool, one wheel cool with two failures, two wheels hot to warm.
I am wondering if my spindles or axles are damaged? Last time digging into them, I did notice what I think is some colorization due to heat on the right spindles. How do you tell if the spindles are wore down or mis- shaped? Didn't think they are tempered. Are the inner bearing races spinning on the spindles?
I am not above putting two new axle assemblies under this thing. Or just buy the new axle tubes/spindles and weld the seats on. Looked at converting to hydraulic disc, but that is still using the same spindles. I guess I need to mic the spindles, where to look up the specs? The bearings came off the spindles, new ones went on easily, thought that was fine. Still, I would think the bearings turning on the spindles would get the spindles hot, not the brake hubs. Vehicle tows great, rolls fine. Doesn't seem to be dragging. Scaled the axles, everything is pretty heavy, but nothing at or over the axle spec weights. 5,200 pound axles, 3/4 ton burb with 8.1L in it, does fine. Have a scale at work so have checked it multiple times setting up the hitch distribution. I would like to think I am not an idiot, but what idiot would realize they are an idiot????? The only thing I have not changed is the axles and spindles. Well, and springs, equalizers and bushings.
Thoughts? What am I missing? new Axles? Motorhome? LOL, gotta get it fixed so we can go camping!!!!
Thank you.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
