Chris_Bryant
Dec 03, 2013Explorer II
A properly wired 4-wire 240 volt plug is what you need- the only reason you cannot use a dryer type is they don't have a neutral, and use 3 wires (and look too much like the 30 amp 120 volt RV plug).. If the 50 amp RV plug fits, it will be fine, as long as the outlet is properly wired.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
