kaydeejay
Dec 03, 2013Explorer
Robin'n'Marian wrote:If the outlet is a 4-prong 220V stove/dryer one, then you can plug right in as it has the split 220V (2 x 110V) that you need.
Is there a way to make a short "extension" type cord that could be plugged in to the 220 v plug in the garage (or whereever)on one end and then convert that plug (maybe with some kind of converter or?)on the other end to the correct 50 amp power source (plug) which we could use to plug in our rv cord? Instead of having to re-wire the existing plug to an RV plug, (since we would want to do this at the homes of several friends and relatives who have these plugins for their welders, etc).
I hope this explanation makes sense.
Thanks
If the outlets are the 3-prong welder type then there is no way to plug your RV in there as there is only 220V available.
As a previous poster said, such an outlet does not have the neutral you need to correctly power your RV. No converter/adapter cord is going to solve that problem.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 21, 2026
