enblethen
Dec 03, 2013Nomad
In the US and some parts of Canada, the elctrical code changed dryers and range receptacles to four wire. Both dryers and range circuits after about 1988 has four wires.
Look closely at the receptacle for number of openings. It should have four on later installations.
It is not only look at but must be tested for proper wiring.
You should not attempt to make an adapter. The receptacle must have a neutral and a ground
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
