wa8yxm
Dec 03, 2013Explorer III
Ok, I will answer, Dryer outlets come in two flavors and one of them can be wired two different ways.
The two flavors are 3 and 4 wire
Now if it's a 3 wire the answer on converting ins likely NO, you will really need to pull new 4-wire feed line to do it properly and safely.
If it's a 4 wire then you need to look at the wires.
There are 4 wires, One white, and either a black and a red, or two blacks, and a bare or green.
Forget the bare/green for the momnent.
Are the black, red and white wires ALL THE SAME SIZE.
If so, then you can convert.
