DryCamper11
Dec 04, 2013Explorer
wa8yxm wrote:
IF all 3 wires in a 3 wire outlet are the same size, a 4th wire (Safety ground) can often be added fairly easily. Not code, but still safe.
Why do you say running a separate ground is "Not code?" I recall looking this up once and IIRC, a separate ground can be run according to code. There were some limitations, requiring it to be run with the existing 3 wire, wire gauge requirements, etc., but I'm pretty sure there was a provision in the NEC allowing it. I considered it at one time. No one should proceed on my comment, it's just my recollection, but it's worth checking up on.
