darsben
Apr 03, 2016Explorer II
Second question; Your transfer switch is mounted behind breaker panel. It is failing. when you tap on breaker panel the switch will move to the shore power position, you can buy an aftermarket transfer switch and mount it on the floor or wall near the breaker panel easier than fooling with removing the old switch. You can also try cleaning and lubricating the old switch but it is an effort in frustration.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
