SoundGuy
Jul 24, 2015Explorer
96Tony wrote:
I'm trying to cut power to the radio, with it's bright blue dislay light, as we are going dry-camping.
I'd guess 12 vdc power to the radio is the same feed that powers the television and the wall plate that powers the antenna head it but it's a simple matter to find out - just pull fuses 'til you find the correct one. That said, if you're going to dry camp on a regular basis I'd suggest that instead of pulling fuses you wire in kill switches to the devices you want to completely disable, just as I did. Since the object of the game here is to minimize draw down on the battery when dry camping don't forget to turn off the fridge climate control circuit, if your particular fridge has one. Plus the obvious - running LED bulbs instead of incandescent will significantly reduce battery draw down.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
