jamjrks wrote:
Am I mixing apples and oranges here?
Yes.
Follow the link given; more information there than you need or want probably.
Your so called 50 amp service is:
50 amps at 240 volts or roughly 12,000 watts.
That can also be used as two 50 amps at 120 volts; still 12,000 watts.
That's your input when plugged in. Might be somewhat less if a generator is supplying the input power.
The converter takes part of that input power and converts it to 12 V to run the portable 12 V systems and batteries; mostly to charge the batteries.
65 amps is probably plenty for your 12 V system. Only time and your specific usage needs will tell the whole story.
