ken_burke
Apr 29, 2013Explorer
ksg5000 wrote:
Lights flickering when your hooked up to shore power is a problem - maybe converter heading south or perhaps your batteries have an issue and your converter is working overtime trying to recharge problem batteries and doesn't have enough power to do extra duty with lights?
I checked the batteries and they are okay. The converter seems to work okay, except at higher DC loads the DC lights flicker. The converter voltage fluxuates by 1.5 and 2 volts.
I found the converter and I think that I can replace it if it bad.
Do you know where the 3 phase battery charger comes from? Is the converter sending out 3 voltages, or is the charger part of the electrical converter panel. I have a 9865 WF converter and it seems to have only one output voltage.
