BFL13
Nov 08, 2015Explorer II
Does the converter plug into a receptacle? Instead of turning off the breaker, unplug the converter and see if the GFCI still pops. Sometimes the converter is on with other receptacles such as the outside one that can get wet and then it is the culprit till it dries out.
Yes you can float the batts with a different charger
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
