MM49
Feb 28, 2014Explorer
alphamorph wrote:Can you correct the condition by setting the choke on slightly?
Thanks for the reply MM49. Why would this occur now (after 4 years)with the old generator and setup. I would be quick to agree if it was only happening with the new generator but both generators are reacting identically when I throw the switch and connect the batteries..... BUT, the problem seems to be overcome if the generator is allowed to run for about 15 or 20 minutes and then connected to the batteries.... so you may have something. It's just that they run so well otherwise, even under very heavy loads.
MM49
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
