nitrofish61's avatar
nitrofish61
Converter charger or inverter charger ?
Batteries not getting enough charge from oem converter charger. Will be looking into a inverter soon. So what would be the best setup, replacing converter charger or getting a inverter charger ?
  • I'm needing a better battery charger than what came with my 5th wheel, but also planned on installing a 2000 watt inverter. Question is, would I be better replacing the old converter charger with a 4 stage charging system or get a inverter charger instead of just a inverter ?
  • A converter and charger are one in the same.
    So an inverter charger would be the one if you are thinking of adding an inverter or replacing your existing inverter.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
