BFL13
Oct 07, 2016Explorer II
smkettner wrote:
If the Powermax would drop to 14.2 volts for 3 to 6 hours(like the IOTA) before going to float-storage mode I would recommend it highly.
The other bug with voltage sensitive Powermax is the RV wire size. Powermax may well go to 14.6 volts but the battery could be just 13.6 or even less. I believe BFL13 has his manual Powermax as a portable right on the battery with short fat cables. This would help any converter. I assume when people are looking for a converter it will be installed near the power center like OEM and subject to the voltage drop.
That would apply to the Iota too. The converter would "see" its 14.6 trigger while the battery is not that high.
Same sort of problem with a solar controller and its "set points" when too far from the battery
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
