Wadcutter
Dec 27, 2020Nomad
Always start with the cheapest solutions first.
First thing check the fluid level in your battery. What your inverter is doing is charging your battery. Low fluid makes affects how the battery will charge. Seen that many many times. Someone will complain their inverter runs all the time. Top off the battery fluid and all is well.
If that doesn't fix it then have the battery checked. It could be a weak cell and the battery is going bad where it doesn't take a full charge.
One of those will usually fix the problem.
There have been a lot of perfectly good inverters replaced, at an expense, when the only problem was low battery fluid.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
