Boon_Docker
Dec 27, 2020Explorer III
Seems like you may have a failing battery.
Disconnect a battery cable for an hour then check the battery voltage. If voltage is below 12.6 - 12.7 then I would suspect the battery is shot.
While you are waiting the one hour (battery disconected), see if the converter fan still comes on when an overhead light is switched on. If it does then I would suspect the converter is failing.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
