jornvango's avatar
jornvango
Explorer II
Jun 07, 2014
Converter fried?
A Mexican campground fried our RV's converter. Our mistake for not testing the outlets at the campground: they were incorrectly wired at 240V! (it also killed our microwave; luckily, the A/C and rest of the appliances were unharmed)
We've been traveling full-time (in Central America) for about 4 months since it happened and really don't miss the converter. We have LED lighting in the RV so we can go without electrical hookup for 3-4 days, before needing to use the generator and the battery charger for a few hours.
Anyway, we crossed back into the States yesterday and now have easy access again to RV repair and/or a new converter.
Question is: does anyone know if it's possible to fix a 'fried' converter? I don't see any fuses on there.
Thanks,
Jorn
  • Hi,
    You are not "Stuck" using the same brand, or anything like that. I would not bother repairs either, unless you have something in the $450+ range. Even fixing my $750 inverter/charger was a difficult decision - due to the $450 diagnostic and repair fees.
    Best Converter has been around a long time, I would be at least checking prices there. It is really easy to install, only slightly more difficult that hooking up the portable battery charger.
    You might even consider installing a solar charging system, and perhaps since you don't really use a 'lot' of 12 VDC power, that will work fine.
    SunE;ec.com
    You can buy a solar panel in the 100 watt range for $100 - $120. Then a 10 - 15 amp controller (good for about 200 rated watts) for a few dollars more. This will allow dry camping for days at a time, especially with your slow electrical use.
    My RV has a E-Meter to carefully measure the amperage into and out of the battery bank. I use about 0.8 amps per hour 24/7 to run the CO meter and propane detector. Once the refrigerator is running, then total amperage is 1.5 amps, so figure about 35 AH daily for those loads. This is about what one of my 120 watt solar panels will put out in a day.
    Fred.
  • www.bestconverter.com I watched a YouTube video on how to replace converter...
    place an order, next day the guy called me and recommend a 4 stage one..an upgrade from my old one... works great.
  • My converter has fuses but I am not sure they all do or whether those fuses would have saved it from 240 volts. I suppose a converter can be fixed but since you can buy a 55 amp PD converter for about $150 I doubt it makes economic sense. Lots of "DIY" converter install on web (and this website I suspect).
  • Fuses may be inside the converter's chassis. Yes, converter's and anything electronic can be fixed. The ugly truth is that there may be as much cost in replacing components as replacing the whole converter. It depends on the amount, if any, of damage done by the high voltage event.
    If your rig is aging, an upgrade to the newer four stage converts is a good idea.
  • I can't help you with your current problem, but THIS will keep it from happening again.
    Bruce
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
