Salvo
May 29, 2013Explorer
I don't believe that's true. Voltage tapers after converter turn-off due to the battery holding up the charge, not converter capacitor. The battery is one huge capacitor.
Your previous converter failed either due to poor design or a bad part. Don't worry about frequent on/offs.
Sal
Sal
BFL13 wrote:
I do see on the voltmeter that after you shut off the converter (when disconnected from battery), its voltage tapers down for a good time rather than drops straight to zero, and from the discussion mentioned above, I understand that is the capacitors "unloading." So now I am wondering if I blew the new in-rush thermistor last year by restarting the converter under full load of 100amps too soon?
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
