ken_white
Nov 14, 2013Explorer
BFL13 wrote:
According to this, the max in-rush is 40a on a single cycle, whatever that means. If it is 40a, why is a 20a thermistor adequate?...
Inrush current is maximum at the zero crossing point for the AC waveform which is periodic or cycles.
The max in-rush value is related to how much energy that can be dissipated, or safely turned into heat, for non-repetitive inputs which is the turn on, in-rush, or transient current.
The 20A rating is specified for repetitive, or steady state, or normal operation energy dissipation.
Both specifications are valid.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
