lorelec
Nov 14, 2013Explorer
Salvo wrote:
This is obviously a design flaw. I believe everybody in the converter business uses a NTC thermister to limit turn-on current.
Overvoltage has nothing to do with this failure. The device is not a transorb.
Sal
That's why I suggest trying a more gradual power cycling first to see if that helps. If not, then perhaps a design flaw. A hot thermistor will have very low resistance, and so will be susceptible to very large surge currents passing through it - which it will likely not be able to tolerate on a repeated basis. The caps may be discharging much faster than the thermistor is cooling, presenting a large surge next time the converter is turned on.
An overvoltage event will increase the peak surge current, and may overstress the thermistor.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
